Luis thanks for sharing this.
I needed this but for showing a layer and also controled the parameter filter value based on what section of a pie chart was clicked.
I made a little script on a No Data Action that goes back one time period.
// Get the parent view.
var parentView = this.parentView;
// Get the view parameters.
var viewParameters = parentView.control.viewParameters;
// Using the library, get the view parameter based on it's name
var viewParameter = this.parentView.control.getViewParameterByName("jvMetricMatLaborRevDateviewParameter");
//Go back one time period on offset
viewParameter.parameterValue.token.offset = viewParameter.parameterValue.token.offset -1;
At first this was really long, I was copying the token then clearing tokens and values then setting the token.
Turns out all that was need was to change the offset value.
This goes back one time period (what ever the level is set to) if that new one has no data it just keeps going untill it "Has Data".
Here is a working link for that article:
This is amazing! Bookmarking this thread right away!
Good idea! Very useful for many cases!
Cool ! We did a google like search in which we invented a key pressed event in JS
Very cool and useful! Great idea!
This forum thread is great, but I would like some way to organise it as it is unwieldy to find the piece that you want when you need it.
I completely agree, it need to be it own forum topic so that we can have a thread per tip or trick (or is it trick or treat today
If you hold down control when using the arrow keys, then it moves 10 pixels instead of the 1 when you donât hold down control key.
Doesnât work on osx Chrome
This is all interesting but very unorganised as there are no categories or anything like that. hard to find things
It should work on Chrome as well (at least it does for me). Can you confirm you are holding down the âctrlâ key and hitting the arrow keys? If indeed it doesnât work with you then we can work with the support team to further investigate.
I wish I could refute that, but you are correct! Unfortunately, when this thread was first created it was prior to our new User Forums structure, making it much more difficult to separate (and navigate) threads. Since thereâs such a great wealth of knowledge in this thread, we felt it worthwhile to keep it (as cumbersome as it is) vs. removing it entirely.
That being said, it is now easier to search for the cheats within this thread using our new, advanced search functionality (you just may need to know what youâre searching for
Weâve also separated our tips of the week into individual threads now so they are much easier to find. A great starting place as well is our business intelligence resources thread - we update this frequently with new content.
Could Lock this tread and make a new Category for new ones to go?
Someone (I know that saying someone normally means no one) should go through this thread and pull out and categorise the gold nuggets buried within.
In the way that the script library / documentations are sorted into categories (data / design etc). the tips can also be arranged like that.
I would if I could create new categories.
I know someone who can do it!
All jokes aside, we are working on finding ways for which we can better organize these âcheatsâ and âtipsâ. Weâve thought about separating them from this category, and applying them into the categories they refer to, however, thereâs the risk theyâll get lost in the rest of the discussion.
Part of whatâs so great about this new User Forum model though, is that the search functionality is very powerful, so while it may not be practical to sift and read through every âcheatâ, if you search for something, itâs highly likely a relevant âcheatâ will appear. So we wonât be locking this thread until weâre certain we can organize all the content that resides here properly within appropriate threads.
In the meantime youâll have to settle for scrolling and searching
Really nice work good job
Very nice Dundas Cheat Sheets.
