What is Script Token? (Video Tip)
Learn Tokens in Dundas BI Part 4/6
Tokens in Dundas BI are a fantastic feature that you need to understand to maximize your ability to create powerful dashboards and reports. This is the fourth of a series of tips covering all 6 different types of Tokens in Dundas BI.
The script token is one of the most flexible tokens in Dundas BI as it allows you to code any behaviour you want to see. The script token uses a C# script to allow developers to completely customize what will return when the user selects a token.
Need more on this? I’ve already done another tip that does a more complex example of a script token. Check it out.
Do you know basic tokens but maybe not some of the more advanced ones? Check out the following:
Introduction to Tokens and Basic Tokens
What is an Attribute Token?
What is a Relative Time Token?
->What is Script Token?
What is a Data Token?
What is a Named Set Token?
