Hello, I had a similar issue with a heat map here:
And am trying to get this to work in a category horizontal axis on a point chart. If I set the top axis alone, it appears at the bottom without labels even if labels are set in the data analysis panel. If I share the same scale with the bottom axis, it will appear at the top but with the hierarchy name appended.
I resolved this issue previously with the advice to set the top axis as the horizontal axis in the Properties panel, but this is only an option for heat maps. In this point chart, I can only add and remove bottom and top axes, not choose which are the horizontal axis. How do I correct this here? If I remove the bottom axis, all the categories disappear and everything is grouped together.
Also, it would be great if we could make it so that top axis labels always appear at the top without syncing with the bottom axis first.
