Need to be able to make column headers vertical
These headers show up when I check Show Column Headers, but none of the column header style options seem to apply to them, and “rotate column header text,” which looks like what I’d want, is greyed out.
If I go to the measure under Columns’ Header Style options, which do affect the column headers, there doesn’t seem to be anything available to flip the text vertically.
Is there a way I can configure this to get the options I need?
(PS please ignore the template mismatches, haha)
We found that checking to show redundant column headers got it to show the measure name in the header, and I was then able to use the solution here to change that name to the hierarchy value and remove the default headers from the viz.
