Click on part of charts does not have data
I have Dashboards and some of the shapes do not have data. I created an interaction to show a popup when you clicked.
I set up parameters to so that the popup only shows data for the part of chart (spicific column or data label value )that is clicked. When I click on any of those that has data, everything works as expected.
But …
When I click on a shape that does not have data, I get the popup with unfiltered data.
I would like to prevent the popup when a no-data for any part of charts is clicked. Any ideas on how I can do that?
I am working on Dundas BI V8.0.2.1004
Thanks…
Ahmad
Hi Ahmad,
While setting up the pop-up interaction, have you made sure that the Bound visual is not the entire chart but the specific series the user will click and see this pop-up? You can edit it and change and the validate if it works fine.
If this is not the case, I would like to know what you meant by “shapes with no data”?
@upasana …
Yup, you got my point
That’s working fine now
Thank you …
