HI,
Had a question bout X-axis labels on bar chart overlapping (see attached screenshots) - when I initially add more than 5 selections in my Payer dropdown (parameter selection) the LABELS on X-axis get messed up (you’ll notice certain bars have 2 payers as labels on x-axis. When I go back to parameter dropdown and quickly uncheck/check any member/selection then labels on x-axis clear up and look good (screenshot #3) - unfortunately, dashboard consumers won’t accept this as a solution :)…
I was wondering if there is a setting under chart properties that could help fix this or if this is a glitch in Dundas BI app? I tried setting horizontal and vertical zooming to show ‘less items’ but did not solve this issue.
Thank you.
-Semir
