We have a metric set created from one cube(used in one dashboard already) to a different dashboard built from a different cube and want to set up a relationship between them. can we create a copy of the existing metric set? will there be any circular references created if we create a copy of the dashboard? our admin mentioned using publish option to avoid references. what is the difference between publishing and copy? cant we create a copy of the object? Please note that both the dashboard and metric set are in the same project folder.
thanks for the help in advance.
