I want to create a table that lets the user select which dimensions are being displayed as the first and second columns. The other options wouldn’t be included in the table, so I can’t just allow the user to rearrange existing column headers.
Here are the dimensions I’m using:
The primary and secondary segment have the same selection, and a user could pick the same dimensions from both if he/she only wanted the data to be binned by a single dimension.
Here’s the formula I put together to allow the user to select the primary segment. "$primary segment variable$ would be a parameter that the user could set.
if ($primary segment variable$==“Employer”)
return $employerName$;
else if($primary segment variable$==“Program”)
return $program$;
else if ($primary segment variable$==“Project”)
return $project$;
else if ($primary segment variable$==“Supervisor”)
return $supervisor$;
else if ($primary segment variable$==“Associate”)
return ($Associate + Username$
I think what I’m missing is the knowledge of how to enable the user to set $primary segment variable$.
