User/Region Level security in Dundas
Hi All
We have a set of users who should on be restricted to see the data for a particular region. What is the best way to achieve it in Dundas.
For example I have User1, User 2 , User 3 …
And regions as NA , GCG , AP
I want User 1 to see only NA Data
I want User 2 to see only AP data
I want User 3 to see everything (all regions)
Note : We are using only one data cube and one de normalized table where we have this entire data.
Thanks in Advance.
Regards
Aditya Dave
https://www.dundas.com/support/learning/documentation/administration-configuration-customization/how-to/using-a-security-hierarchy-to-filter-data-by-user
This is what I use. make your regions a Hierarchy and then use it as a security Hierarchy.
https://www.dundas.com/support/learning/documentation/analyze-data/how-to/how-to-create-a-custom-user-hierarchy this is if in your data it is not detected by Dundas as a Hierarchy.
Hello @adityadave,
I’ve implemented a similar concept of row level security using a security hierarchy and custom attributes and it’s working really well.
https://www.dundas.com/support/secondary/using-custom-attributes-to-filter-data-by-user
Thanks a lot for the input … Let me try to implement it.
Thanks a Lot for your advice … I will be following the same and see how it goes.
