There are many ways one can tackle the user navigation within Dundas BI. One of the most common ways, is to configure a default landing page so when the user logs on, they land on a specific dashboard or report.
In some cases, setting that default landing page is just the beginning and there is a need to ensure that when the user clicks on the Dundas BI “Home” button from the main menu, they will land back on that custom landing page and not the application default home.
In order to achieve this setup, you can simply use the “Always Use Custom Home Page” configuration from the Admin -> Setup -> Config menu and start controlling your Dundas BI Home page.
A picture is worth a 1000 words:
When checking on the “Always Use Custom Home Page” configuration, you will allow users to click on the home button and get to their defined Home page vs. the Dundas BI default home page.
This is the configuration you would want to set for this behavior:
