Remove Outlier Values
Outliers in your data can skew your data analysis and lead to errors in your final analysis. In Dundas BI, there is a quick and simple way to remove outliers so you can focus on the correct data. To remove outliers from your data, use the following formula: OUTIQ.
This function will automatically calculate outliers in a set of inputs using interquartile range computations to eliminate outliers in your charts.
