Adding multiple hierarchies/dimensions to a Data Table will result in each already having their own column in the visualization.
Did you know that you can save space by having these hierarchy/dimensions columns compacted into a single column? Go to Layout and look for a property called “Row Header Layout”. Changing this to “Single Indented Column” will save you a significant amount of save in your visualization.
Much more compact!
