Sometimes, you simply want to clear ALL your filters on a dashboard with the snap of your fingers (or at least with the click of a button). However, you likely don’t want to have to deal with the hassle of scripting to make this possible.
One easy trick if you want to have a full reset button, is to simply add a button with a navigate interaction that brings you back to the same page . This will essentially reset everything on the dashboard and it doesn’t require any scripting! It’s that easy!
HOWEVER, if you do want to use a script, I recommend checking out this Forum topic >>>
