Not sure which filter you should use for your data? You’re not alone! Filters are only designed to work with certain data types. For example, you can’t use a Single Date Filter unless you have data that is in the Date or DateTime format.
Dates are obvious, but how do you know what filters can be applied to which types of data?
TIP - The titles give you a hint about what kind of data type you should be using if you want to use these filters! For example, if you want to use the Textbox , your data probably needs to be a string or text.
