Time Dimension
Hi ,
Is there an option in Dundas to use 2 different Time dimensions in the same chart ? I need one metric set to use 1 Time dimension and the other metric set to use another dimension ? Is this achievable ?
In your case, you could just create a duplicate of the column/dimension that you want to have represented by 2 different time dimension, either in your data source or via the data cube (calculated element). The original column/dimension can have one dimension applied to it, then the duplicate have the other.
