Did you know that Dundas BI has different search options available when looking for specific text? By default, the content creator can choose the type of search the user will experience, but you can push some of this control down to the user if you want. In this video, you’ll learn about simple text search, the search/update button and a simple script to allow the user to pivot the type of search used on their dashboard. Finally, I’ll discuss the differences between Exact, Contains, Starts With, Ends With and Match(wildcard search).
Check it out.
Code Example:
var value = dropDownList1.value;
if (value == "Starts With"){
parameterTextBox1.control.searchOperator = dundas.QueryFilterOperator.STARTS_WITH;
else if (value == "Ends With") {
parameterTextBox1.control.searchOperator = dundas.QueryFilterOperator.ENDS_WITH;
else if (value == "Equals") {
parameterTextBox1.control.searchOperator = dundas.QueryFilterOperator.EQUALS;
else if (value == "Contains") {
parameterTextBox1.control.searchOperator = dundas.QueryFilterOperator.CONTAINS;
else
parameterTextBox1.control.searchOperator = dundas.QueryFilterOperator.MATCHES;
Also, check out my Live Sample.
