Styling NA values
I displayed my Empty values as NA.
Applied missing data style and set the background for missing data to white
Applied styling to other data in the field using states
But my missing values get displayed with yellow background instead of white.
Regards,
Sam
At the moment, Empty values are treated as Zero by the states. I submitted a feature request to change this behavior and will let you know when that happens. Until then, however, you can work around this by adding a formula measure and setting up the states based on that measure. For example, use the following script for the formula measure:
if($value$ == 0)
return 0
else if($value$ >=0)
return 1;
else
return -1;
Image title
Next, set up states to distinguish the negative value corresponding to missing data and select the property Apply state styles to entire row.
Image title
Now you can style and hide the formula measure to get the result you were looking for.
Image title
