I am trying to connect a filter to a stored procedure. My problem is that I have a stacked bar chart visualization with ~15,000 bars. This means the dashboard can hardly load (takes about 5-10 min to load initially and after each filter action).
Ideally I would attach the filters to a stored procedure and pass “dummy” parameters to limit the number of displayed records. The user should then still be able to select their filter criteria from the dropdown.
For example, one of the filter criteria is called “Benefit Type”. I do not want the user to have to remember all 150+ Benefit Type codes, but instead, be able to click the filter and see all the options listed to then select which they would like to see information for.
I have tried passing parameter values from dashboard to stored procedure, stored procedure select, and a manual select but have had no luck.
Should I try a bridge parameter? If so, where can I find some documentation to help me with this?
TIA
