States on table - conditional formatting
Hi guys,
I have a table with several columns that have percentage values within.
What I need is to replicate the conditional formatting option from excel, in my tables.
So, on each column, I need to se up a state on which the highest value gets a color, the lowest value another color, and gradient colors for the rest of the values. Each column should have this rule.
This is what I need to achieve:
Any ideas?
Thanks for the support!
Hello Octavian,
You can achieve this by using an Auto Color Rule, which will apply a color gradient (which is customizable), based on the weight of the value. You will have to apply this color rule property to each measure in your visualization. Here is a support article overviewing how to apply a color rule to your visualization.
Inside your visualizations property panel -> go into the measure -> under the Look header you can then add an auto color rule to your visualization.Image title
If you want to have your cells with the value of zero display with a white background, you will have to add a state style when the measure equals zero. You will have to add this state for each measure in your visualization. Here is a support article overviewing how to set up states for your visualization.
When you setup your state, you will want to change the color when the value equals the constant zero:
Image title
After you configure your state condition, you will have to modify the state style to change the color to white:
Image title
Result:
Image title
Please let me know if you have any questions about this.
Thank you very much! I will try it but surly it will work just fine!
States...
https://www.dundas.com/Support/learning/documentation/data-metrics/set-up-states-on-a-metric-set
You can easily set up sme staes just like the condition in Excel.
