Is there a way to use custom icons for the state styles? We would like to use a different symbol than those available in the Look > Appearance > Symbol dropdown list.
StateIndicator - custom icons for state styles
Wherever you can specify a colour in Dundas, you can usually specify an image.
Try setting the shape to ‘rectangle’, and then in the ‘Fill’ section in ‘Appearance’ change ‘Brush’ to ‘Image’.
That should allow you to select an image to fill the shape.
Hi Tallan, David is correct. For more information you can refer to this link - https://www.dundas.com/support/learning/documentation/data-visualizations/using-a-state-indicator#h5-1-using-an-image-for-a-state
