Showing old parameter selection
Hi, I have dashboard in which I have selected parameter value other than default parameter. However when I open dashboard next time, it is keeping selected parameter value as default selection instead of design time default. I have denied Personalisation also in metric set I have checked bypass cache. Still I am facing this issue. What might be the reason? Each user is facing it.
I think this is the same issue as when I go in edit mode then test it in view mode and mess with filters.
I noticed I have to remember to make sure to set the default back before checking it in.
my Suggestion is open it for edit and open the Parameter setting tab and check the default there, do not preview it, check it in and then check it.
