Hi Reynaldo,
Please find below two solutions to handle this.
The first solution works without script with all dashboard Re-size modes including Responsive with template grids.
The second solution is the scripts, which works with Template Grids but not in Responsive mode.
I hope you find them useful:
First solution – Using Layer, Rectangle and labels:
You can create a new Layer, and then in the target cell of that layer, create a Rectangle which contains one or more labels, each representing one command, as shown below:
Add the script on Click event of each label, so it does what they are supposed to do.
Add ‘Change Layer’ Interaction to Click event of the labels as well, so it hides the layer containing the context menu after it is clicked:
In the Click action of your button, create a Change Layer Interaction, so it shows the layer once this is clicked,
Hide This layer by default, by clicking on Eye icon as shown below:
Switch to View mode and test it with different screen sizes.
Now, you may change properties of the Rectangle and Labels so it looks closer to a real Context Menu.
Second Solution (which works with Template Grid, but not in Responsive mode):
In the sample below, I have used Terrence’s sample code and some of your scripts to calculate the coordinates that the Context menu should be displayed.
This script is added to the Click action of a button that is placed in Cell 6 of a 3X3 template grid.
debugger ;
// Calculate Coordinates (top and left)
var layerAdapters = this . parentView . layerAdapters ;
var layer = layerAdapters [ 0 ];
var screenWidth = layer . container . clientWidth ;
// Please change the templateCell index accordingly, (it should be the index of the cell that contains the button)
// Template cell index starts from 0 and is from left to right - top to bottom
var widthOfTemplateCell = this . parentView . templateCells [ 5 ]. width ;
var templateCellLeft = screenWidth ***** this . parentView . templateCells [ 5 ]. left ;
var screenLeft = (( screenWidth ***** widthOfTemplateCell ) ***** this . left ) + templateCellLeft ;
var heightOfTemplateCell = this . parentView . templateCells [ 5 ]. height ;
var screenHeight = layer . container . offsetHeight ;
var templateCellTop = screenHeight ***** this . parentView . templateCells [ 5 ]. top ;
var screenTop = (( screenHeight ***** heightOfTemplateCell ) ***** this . top ) + (( screenHeight ***** heightOfTemplateCell ) ***** this . height ) + templateCellTop ;
var coordinate = new dundas . controls . Coordinates ( screenLeft , screenTop , null , this . getService ( "CanvasService" ). canvas , null , this );
var commands = [];
// define new commands and push to the command
var parentMenuItem = new dundas . Command ({
caption : "Share" ,
categoryName : "Share" ,
action : function () {
// Do cool stuff here
}. bind ( this ),
subCommands : [
id : dundas . Utility . createGuid (),
caption : "PDF" ,
categoryName : "Export to PDF" ,
description : ‘Export to PDF’ ,
editModeOnly : false ,
var share = new dundas . controls . ExportDialog ( dundas . constants . STANDARD_PDF_EXPORT_PROVIDER_ID );
var sharePanel = share . show ();
}. bind ( this )
commands . push ( parentMenuItem );
window . dundas . context . getService ( "ContextMenuService" ). showContextMenu ( commands , e . originalEvent , {
"getAdapter" : function () {
return this ;
}. bind ( this ),
"coordinate" : coordinate . convertCoordinateKind ( dundas . controls . CoordinateKind . PAGE , null , this . getService ( "CanvasService" ). canvas . getVision (). scale )});
I hope these help.
