I have a stored procedure that I want to create a data cube for. It has 6 outputs and in the where clause for the SQL Server stored procedure, I have a @datestart and @dateend as parameters. How do I set those in the data cube? The field that I have the where clause is not a part of the the final output.
Setting up parameter for a where clause from stored procedure
Thanks James. I followed these instructions, however, when I go to connect the string value filter to the table, the placeholder doesn’t show up in the filter visualizations window. Any ideas?
Not with out looking at your project, I suggest contacting support they can set up a web-ex
