Is there an option to change the token order? I’d like to set it chonologically rather than alphabetically:
Setting token order
Hello Lindsey,
Unfortunately you cannot change the order of the tokens, they will be sorted alphabetically. You can however rename the tokens and add a number at the start to get the sorting you need.
I think putting numbers in front of these could confuse people, e.g. “5 Rolling Year,” and it would also depend on which dashboard they were being used on, since different dashboards use different sets of the same tokens, so we’d need to create multiples of the same token with different numbers? I think it would be better to be able to sort the tokens.
