The documentation says that by setting the Default Home Page option in the config, you can set up a custom home page for users. I have created a custom home page and set the relative URL in this setting. However, it doesn’t seem to route the user to the custom home page unless I also set the Always Use Custom Home Page option to be checked. When I check that option, then it does route the user correctly.
I would like to put a link on the custom home page that will allow power users to get to the original view of Dundas when they want to, with the menu on the left, the thumbnails in the middle, and the explore on the right, so they can browse or create as needed.
Can someone explain if the intended behavior is that the Default Home Page config setting does not work unless you set the Always Use Custom Home Page option as well?
And/or does anyone know what URL could be used in this case to allow the power users to view the original Dundas view if they are not just in consume mode, they want to create or edit?
Thanks.
