Select Parameter/Filter First Dashboard Experience (Video Tip)
Sometimes the dashboard/reporting experience you are looking to provide is just the ability to search a large dataset and get specific results. Here is an example where the user can be prompted to select a set of filtering options before any data is loaded onto the dashboard. Additionally, this concept works very well with text-based search, which I covered in a previous video.
Check it out!
Thanks for the tip Jeff and Pumpkin!
I may consider this approach. Typically I have parameters set to load a smaller set of data which helps with pre-load processing times but I like this idea!
My pleasure. Would love to hear how you make out if you decide to try it.
