The Dundas Script Library is a place to view, interact, and download script samples. Within our library, there are samples on how to add D3 visualizations to the dashboard; samples on creating breadcrumb controls to navigate the hierarchy level parameter; and even samples on how to use a timer control.
But our library isn’t complete.
Part of what makes Dundas BI so appealing, is the unrivaled flexibility. And it is for that very reason, why the Dundas Script Library, will never be truly complete.
We’re willing to bet that you’ve done something (anything!) with script, to enhance your dashboards with samples that we currently don’t have in our library. What we’d love, is to showcase your scripts (they can be small – a couple of lines – or they can be big) in the Dundas Script Library, and give you all the credit for it (if you want the credit that is)!
This thread will remain open indefinitely, and you can share new scripts daily if you want. There are just a couple of rules. If you wish to share a script (I mean, why wouldn’t you want to!), you must:
- Post an image/video link of your sample in addition to an explanation of the use case for that script
- Post the sample Dundas BI export (.dbie) file. The sample should be created in a dedicated project (not 'Global/My Project') and should depend on a dragged-in Excel/CSV file as the data source
- Avoid posting samples that can be easily done via the standard UI, unless there is a good use case for doing it via script
- Even if you don't have ideas to share - we would love to get your feedback and comments on other user's samples
- We reserve the right to select which samples we choose to publish and which ones we don't
Also, for every sample you publish, we’ll award you 25 points, and if we publish it in the Dundas Script Library, you’ll receive an extra 300 points!
It’s just that simple!
So what are you waiting for – let’s see those samples!
