Hello everyone,
I want to allow the user to use two templates in one report.
I want to create a button with script, click on it will replace the templet
Does anyone have a solution?
Thanks!
Hello everyone,
Thanks!
Here is a sample script that you can use with the Click action to replace a template:
var canvasService = this.getService("CanvasService");
var canvasAdapter = canvasService.canvasAdapter;
var dashboardService = this.getService("DashboardService");
var promise = dashboardService.getDashboardById("bf17833a-4d6f-44c5-bd41-1b2b97920f88"); // use your template dashboard id that you want to set
promise.done(function(obj){
var templateEntity = dundas.Utility.cloneAdapter(obj);
var templateAdapter = new dundas.view.controls.Dashboard({ control: templateEntity });
// First clear the current template
canvasService.clearTemplate();
// Now load the new template
canvasService.loadTemplate(templateAdapter);
Depending on your use case, you may also explore other ways:
