Im a bit confused over the advantages and disadvantages / when I would use a scorecard over a Report or Dashboard?
Thanks,
Alex
Thanks,
Alex
They are very similar. The main difference is in supporting multiple page configuration. You will see this difference the most when exporting to PDF, since you can essentially customize how every page looks.
You will see that a report has some areas that a scorecard does not:
As well as some page-related properties:
Another difference is that the report designer offers a Labels tab to help you work with placeholder and view parameter labels.
Hope this helps.
