Hi, When publishing projects into new tenant projects a new reporting connection get created suffixed with '- copy'.
My issue is I need the newly published cubes to look at the original reporting connection, at the moment I have to go into each individual cube and replace the tables I am using with the same tables from the original connection, is there a way I can just tell the cubes to use another reporting connection without checking out and editing each one?
Regards
Mike
