Report Schedule
I’ve a report with a datetime filter. My question is, I need to send this report on a defined schedule, that would include all the records 15 days back from the day that the report was scheduled to, how should I configure the filter/parameter in order to achieve this?
Example: Suppose that the report is scheduled to run on 16-12-2021, I want all the records where the date is bigger than 1-12-2021 until the scheduled date, which is 16-12-2021.
Thanks,
Luis Silva
I believe you would be able to use the date token, Advanced feature, just set the lower range to -15 days from the current date and the upper range - 1 from the End of Current Day. Then when you schedule your report, every time it runs, regardless of when, it will always apply the previous 15 days filter.
Thanks Kelly! That’s what I wanted.
