Is there a way to remove/hide Rank value for Grand Total? I look in the Rank properties and do not see where I can do this.
If you go to the data analysis panel of your table and then click on the pencil icon beside the rank measure, you should see an option to create a custom totals calculation. You can use this and then simply place a null into the formula bar and that should turn the grand total cell for rank into a blank.
That works, thank you!
