Point Chart + Hover Over
I have created a point chart in a scorecard. When I hover over the x axis labels on one chart, every dot in the other repeating charts become highlighted. How am I able to stop this from happening?
This behavior is managed by the Brush View Parameter, which you can find in the Parameters tab at the bottom of the designer window. You can edit this parameter to change which data visualizations it applies to or delete it altogether.
I should point out that this parameter is created with the scorecard/dashboard and cannot be recreated easily. I recommend unlinking it from visualizations rather than deleting.
Hope this helps.
