HI,
I sort of ran into this issue. Basically, while trying to collaborate with another team member on a recent project we ran into several issues by trying to work on the same dashboards (one dashboard with several views/slides), so long story short, we decided to publish from our individual âMy Projectâ projects into GLOBAL. Now, Iâd like to do the following as painlessly as possible: basically PUBLISH everything for this project we did (so final dashboard + all dependencies which include metric sets, scorecards, and DW Cube which are all stored in GLOBAL project. Spend some time trying to do this and I ran into an issue where I can COPY/PASTE of all of of the dashboard and its components from GLOBAL project back into âMY PROJECTâ, however, when you click on dashboard in âMy Projectâ or. a Scorecard that is a part of that dashboard or a metric set it says for all of these projects that they still pointt to DW cube in GLOBAL project. What I am trying to do is once I publish my dashboard from GLOBA project back into âMY PROJECTâ Iâd like for dashboard with its elements (connectors, cubes, metric sets, scorecards, etc.) to point to âMY PROJECTâ so it looks like this was all built from scratch in âMY PROJECTâ. Seems this may not. be possible
? It is great that I can publish always from âMY PROJECTâ to anywhere where once published dashboard and all of its elements will show as pointing to the project where it was published, but this does not happen when copied/pasted into âMy Projectâ? Again, this is something I ran into first time while trying to collaborate but I can see this coming up again down the roadâŚ
Hope you may have some info for us in regards to this matter.
Thank you.
