I have a data label with a count of a measure.
if there is at least 1 or more then everything is good.
When there is none, I am not getting zero I get “No Data” .
I have tried many combinations of the ‘Missing Data Input Rule" thinking well “No Data” is equivalent to “NULL” but I still get "No Data’.
Then I check the “Disable No Data Indicator” but it still shows, so I can not put a label under it to be seen when the No Data is hidden.
Any ideas on a work around?
Update no the “Disable No Data Indicator” is working all of the sudden. and now it is not again…
seams I have all three conditions. the closest to what I want is the Q4 “Jeopardy:” with no number, would like to see a zero there.
All of them are set up the same way but acting different.
I have by pass data cache enabled.
