Map Symbol Binding and Colour Rules (Video Tip)
Here is a tutorial to show how to dynamically bind symbols (points) from your data using Latitude and Longitude values to a map in Dundas BI. I walk you through how to generate the points/symbols from your data, handle aggregation issues, and customize the colouring based on data.
