I already know there a huge possibility that the answer is going to be use Apply Styles, but that is too over sweeping for what I am wanting (at least the way I understand it).
I just want to know if there is a way to set the defaults used for the Fonts settings?
Like Color, Family, Size, Weight and others (but I don’t currently set those).
I mean there is already a default used each time you make a new Metric Set it is using some default set of setting for all this. I just want to go in there and change it to Arial Bold Black (RBG 30,30,30) and have a larger default font size righ off the bat when I create a new one.
Also have the default color of the Axis Appearance Stroke to be Black (RBG 30,30,30).
Where is this? if it is an Admin only thing mine does most every thing I ask of them.
Thanks
James
