Greetings,
How do I go about giving a dashboard multiple filters that are independent of each other?
Backing up a bit. I have a manual select data cube pulling from a very large data set, that grows daily.
The client requires that customer service be able to look up any record from anytime via the dashboard. There are currently 5 different data elements that customer service can potentially use to identify a record.
I’m going back and forth with support to figure out how to pass a parameter back to the sql server. (due to my lack of experience writing scripts)
Until then I’m using a warehouse storage and would like to have those 5 different data elements as filters that are not dependent on each other.
The available values that customer service will be provided to locate a record will change between the 5 based on who called etc…
I hope this made a little sense. i hit my frustration wall for the day and came here to see if anyone had a solution.
Thank you in advance !
Jason
