Yes, if you add the image component from the menu it has a src property in JavaScript. This property expects the URL of an image, or you can use one of the image resources in Dundas BI if you’ve uploaded them.
You can set it with something like:
image1.src = "http://mydomain.com/myimage.jpeg";
You can do this on a button click action, and as well on a timer by adding the timer component. All you’d need to do is then write the code to select what image is displayed. If it’s truly random you can use Math.random() to generate a number and then map segments of that number to different URLs.
If it’s rotating then you can just set a counter on the window and increment it.
