Upasana,
Unfortunately Work, Hours and CPH are separate formulas so I can’t use the formula you suggest in order to create a column containing just the Work value. I was able to get the Rank of the work, and the ranking in the grand total column appears to be correct. What I can’t figure out is how to sort the Associate names based on the new “Rank Work Expression Expression” formula.
I think the issue is that I want to sort a heirarchy (“Assoc + Username”) by a measure (“Rank Work Expression Expression”). The Dundas support page says this is possible, but I’m not seeing the measures on the configure window for “Assoc + Username”:
https://www.dundas.com/support/learning/documentation/analyze-data/define-custom-hierarchy-sorting
Also, the (All) column to the right of the Grand Total column is unneeded and I can’t figure out how to make it go away. The (All) next to Monday, 1 Nov is the total for the week, but the (All) next to the Grand Total is just another copy of the Grand Total. I only need one.
