How to Make a Live Button Map Visualization (Video Tip)
Being a bit unorthodox, I decided to create a unique form of navigation that also displays live data. Behold - The Button Map Visualization! Patent-pending on the name of this thing.
The map control itself in Dundas BI is wildly flexible as a visualization tool for your dashboards and reports. Some of the customizations that I show here are just touching the surface regarding what is possible with the Map. I’ve previously done a whole video covering many of the potential use cases for the map visualization in the Dundas BI platform. Check it out.
https://www.dundas.com/resources/off-the-charts-tips-from-an-expert/getting-started-with-dundas-bi/what-can-you-do-with-the-map-in-dundas-bi
