TL;DR: how can I invalidate the cache of one cube?
Long version:
I want to send a few notifications, based on one data set. The issue is that the number of notification depends on the data set, and I do not know in advance how many will be set. Dundas cannot handle this out of the box.
I worked around the problem by defining 1 cube and 1 notification. The cube reads its data from Postgres and sends 1 export. Outside Dundas, In Python, I wrote this kind of script using the rest API:
alldata = get_all_data()
for d in alldata:
update_postgres(d)
send_notification()
In short, the cube and notification do not change, the underlying data does.
It works very nicely but for one issue: Dundas caches the data it receives from the cube. So my question is: how can I either invalidate the cache, either configure the cube (or metric set, or dashboard) to not use the cache?
I found this call /Admin/Clear/ to clear cache, but I can only invalidate all cubes or none, I cannot select one specific cube.
Thanks,
