How to fit X-axis in a metric set without requiring to scroll
I have atable for annual data from 2003 till 2018(Forecast). As I create a Metric Set for it, I have to scroll it horizontally to see the chart beyond 2017.
How can I fit the whole chart without requiring to scroll?
There is a setting for this.
In the main properties window of the chart you will see 'horizontal zooming'. Click on that, and in the properties there uncheck 'scroll bar visible'.
Cunningly hidden, but Support pointed me towards it.
You may also need to configure 'maximum visible categories' from that menu, also you may need to 'zoom out' from the right click of the chart on the view mode.
Thanks, David.
@david.glickman and @ravi.bansal
Also Maximum Visible Categories should be set to max possible data points for that series…
