Map files using a ShapeFile to display any geography that you might want to see. Once you have a custom map, you can use the map data visualization in Dundas BI to display data. I’ll show you how to find a map file, convert it to an appropriate format, simplify it to make it usable, and finally use it to present data using Dundas BI.
