How to display Multi-Level Series Label & Legend
I have a Chart for a Multi-Level Hierarchy with 3 levels: Area > Municipality > Community. As I select a value from any of the 3 levels, the chart updates correctly. But, the legend and the series label show Top Level Name only. For example, if I am displaying chart for Brampton (which is a municipality under Peel Area), the series label, as well as the Legend, still says Peel. How do I make sure that correct value (Brampton) is displayed in the series Label and the legend?
Hi Ravi,
I have tried replicating your use case and it seems like this is the default behavior of the application when you bind a value filter with multi-level hierarchy. A work around is to right click on the bar (series) in the chart and select “Expand” from the context menu. This will update the legend associated with the chart and the tooltip to the correct level of the hierarchy.
I am forwarding this issue to our R&D team to see if we can improve this behavior. Will keep you posted when I hear any feedback from the developers.
I hope it helps.
Regards,
Razi
