We ran across a blog on Dundas website that talks about Heat Map with an example of sales people images display along side the heat map (see screenshot below). The blog didn’t go into detail on how to get the image to display.
Here’s the link to the blog: https://www.dundas.com/resources/blogs/from-heat-map-charts-to-color-scale-legends-experience-dundas-bi-version-7
We were able to reproduce a similar heat map chart using the Heat Map visualization. However, we couldn’t figure out how to get the images to show along side the names and the heat map. We have a field that stores the URLs pointing to the images. I tried adding the URL field to the metric set that the heat map visualization uses. That didn’t work. I assume that we would need to use the Data Image visualization to get the image to show. If that’s the case, how do you link the Data Image visualization to the Heat Map so that when the Heat Map shows 10 rows of data, the Data Image will show 10 images as well.
