How to deploy offline maps in visualization.
I want to use offline maps in my visualization. Is there any way to use offline maps. If yes Please suggest how to do it.
Are you talking about loading a map that is not hosted online and does not need an API cred to use?
https://www.dundas.com/support/learning/documentation/data-visualizations/using-a-map-visualization
https://www.dundas.com/learning/theres-a-map-for-that
Maps aside - Dundas BI is an online only tool meaning that all visualizations require an active and live connection. Please do clarify and we’re happy to help answer your question.
Thanks James for your response.
Actually I want to use a map which can we used if there is no internet connection. At the time of development we have internet but sometimes at the time of presentation we don’t have. So I need a map which can work without internet. Is this possible with dundas ? Some BI tools have this facility.
Thanks Jeff for your response.
I saw your video before posting this question. Purpose of using offline map is sometime we don’t have internet at the time of presentation that’s why I need a map which will work offline.
Thanks for clarifying Anupam. You’re best bet is probably to use the export capabilities if you don’t have a live connection when giving a presentation. You can export your map (or whole dashboard) to image or Power Point, (or ever Excel) and then do your presentation from there.
