I had created a stored procedure using SQL and it run well. But when I drag into a blank data cube, an error message pop up saying "The element name cannot be empty or null".
Not sure the "element" refers to what???
Thank you.
Thank you.
Could you be a bit more specific? maybe share the SQL code (or something similar to it)?
Try changing
SELECT SUM(#tblCost.CPMPA)
FROM #tblCost
To something like
SELECT SUM(#tblCost.CPMPA) AS [SUM_CPMPA]
FROM #tblCost
Hi Elia,
Yes, it works!!! Million Thanks.
