How to change label border color on button click?
I would like to change the color of the border of a label on button click. I’ve tried to assign a SolidBrush object to the color property, however, it did not change color.
Am I missing out on something?
var newColor = new dundas.controls.SolidColorBrush("Red");
label1.border.color = newColor;
Regards,
Renzi
The sub-properties of border aren’t tracked when they are changed, so changing the color property to a new brush is not sufficient.
You can create a new border and assign it, although re-assigning the existing one should also work after you’ve updated a property on it:
label1.border = label1.border;
I was just looking at this when Terrence replied and I thought I’d also point out that the .color part of the border uses dundas.controls.Color and not dundas.controls.SolidColorBrush.
I see thank you for your replies. I will try it out.
