Hide column if all data is collapsed
I have a table visualization, where I want to default the last hierarchy to be collapsed. In this case, it is specific IDs, so I want the user to have the option of expanding to be able to see the IDs if they want to investigate further.
However, when I have the ID hierarchy set to “collapse all”, the column still shows up with “(All)” in each row. Is there a way to hide that column and only have it appear if the user expands the preceding hierarchy?
A good example of this is the date hierarchy, which adds a column for each level as you drill down from year to quarter to month to day.
Thanks!
Hi Molly,
If it makes sense or works for you, you could make the IDs a second level or higher of an actual hierarchy created from the left menu, which would behave like the date hierarchy you’re describing.
